1977 K10 Frame with 86 Cab Help
OutLalli
Pa
Bubby
I have a 1977 K10 Frame with a MINT condition 86 Cab. I know I have to use the cab mounts for the 77 but I need to know how the fenders and radiator support and such are going to work. Any information will be appreciated. We have a 86 hood already I know they were changed as well.
Thanks!
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
I had to oval the holes in the 84 core support I put on a 78 frame. Depending on the year of the core support you may have to do the same. Everything else was same ish.
kkgp81
Kelley
You would use the bushing set for the 73-80 frames. They have simple round holes on the frame mounts. On the 81-87 they are round holes with flat sides.
grayson1210
