Replacing fuel tank
Joe
Janesville, WI
Joe
I need to replace the fuel tank on my 82 GMC Shortbox. It has a TBI motor that might be from a different truck.
I know I need to replace the tank and straps... what else should I do when I'm in there?
Thanks
What about the fuel sending unit and seal? This place has good pricing. Also clean your ground wire while under there. Also I'd check/replace any rubber connection lines and clamps. :)
http://www.tanks-to-pans.com/
MrMarty51
Eastern Montana
Martin
Some people say yes,some people say no,but,My personal experience is to pull the box.By doing that,all the connections can be thoroughly cleaned before any disconnections and it could save allowing a bunch of dirt to enter into the fueling system.
As HRPC once stated,two tough guy,or,four sissies,is all it takes to lift the box and set it onto a couple of saw horses,My personal experience,also,is,unhook the ground strap to fuel filler neck before lifting the box.please do`nt ask Me how I know this.:emotions122::emotions33:
jaderosajr
