kickdown hookup linkage won't re-seat after cable change
gordo9
idaho
gordy
Sierra 2500
howdy all- was just changing kick down cable on1985 automatic th350. It seems I "may" have pulled the pin a little too much? cable is back on but the hookup pin from inside the tranny won't drop in. been gently giggling, moved gear select any suggestions? or is this a drain fluid remove pan situation? thanks gordo
@NickTransmissions
duncan_schawalder
