Dynamat alternative
fowjacob
Lubbock,TX
c3500
383 Stroker
I went to lowes today and pick up some peel and seal which is actually used for water proofing roofs but it's actually the same thing as Dynamat but its alot cheaper
I payed $16.45 a roll which is a 6" by 25' roll or 12.5 sq ft
Pros: cheaper then Dynamat, pretty thick
Cons: 6" wide, asphalt based(you can only smell it if your nose it right there).
Ill get a picture of it in the truck when it gets installed
Wonder how good the adhesive is on that.
Domer
El Cajon, Kalifornia
Kyle
6-71 Blown 355
Go to sounddeadener.com and you can get fatmat for about the same price per sq. Ft...
Stickman
