Axle problem
ross 16a
usa
eric
Hi. I’m new to the forum. I have a 1975 k10. I just replaced upper and lower ball joints in both sides. Now my axle u-joints are rubbing the lower ball joint nut. Does anyone have an idea why it’s doing that?
Strick
Dunn, NC
Harold
C20 Crew
Welcome to the site from NC. I rebuilt a Dana 44 HD a few years back & used China's best stuff from the local auto store; that's what the customer wanted. I too had problems with the axle shaft rubbing the upper ball joint. It took a few turns on the spanner nut adjuster on top to get enough clearance on the axle shaft...after polishing the joint cap with the grinder.
HS
ross 16a
usa
eric
Thanks. Yeah I was thinking grinding the lower ball joint but down a hair.
Stickman
