Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
For the longest now I have had these pesky transmission problems. They are to extensive to go into again for those of you who don't know about them but you can look for my name on threads on this site and read some of the earlier ones.
But after all this time I thought I could do what I wanted to do in getting my trans back to, or rather where it should be by just getting it overhauled. But I might have known it wouldn't be that easy as nothing is ever that easy for me and what I want to do. I always have to fight for what I want. What I'm talking about is, I did get the transmission overhauled by a highly reputable shop. They did a okay job but they weren't able to get the tuning done because the suspension was screwed. I needed to have it overhauled first because they didn't want to drive the truck in the shape it was in, and I didn't blame them. The suspension rebuild has been done.
Now I have discovered that either they put the wrong spring set in the governor, which I suspect because I turned the screw in the back of the modulator valve two full turns in and it didn't make the trans shift later like I wanted it to do, but 1-2 shift a bit firmer which is okay but did not solve the problem of a overall early shift. I want it to shift later like it used to do. I'm completely unable to whind it out in Drive. As soon as it hits 20 mph it already shifts to 3rd and that's it no matter how much gas I give it taking off. I can whind it out if I manually shift it, I tried it today and it's fine. It's the governor I strongly suspect. It's probably a light set of springs and may not be the weights. But I don't know, I have no idea what they did to it, I have no idea what they found was wrong with it, I didn't get any kind of paper saying what they did to it.
But since they couldn't drive it there is no way they could have test drove it to see what the governor was doing unless they just test drove in street traffic which wouldn't have told them anything. It needed to have been tested a WOT to really get an idea of what the governor is doing.
But here's what I discovered yesterday and that is I'm still using the 2 bbl. kick down bracket when it had a 2 bbl. on it. The bracket is fine where the throttle cable is, it's on it's own bracket. But the kick down cable which is on another bracket behind the throttle one is to far back for the kick down to come close to attaching to where it should go on the carb linkage, without that stupid little link bar thing. The truck has a 4 bbl. on it now with a Edelbrock Performer intake on the engine with a Holley 600 cfm 4 bbl. So since the kick down cable is out of position it won't kick down anywhere near where it should, heck it won't even work right. So, tonight I ordered a Holley kick down bracket strictly for a 4 bbl. on a Edelbrock intake on a small block Chevy 350 and a TH350 trans.. I'll get that on and see if at least I have the kick down restored. Then I may have to call that shop back and tell them they needed to have done more tuning with the governor and see if they have time to fool with it.
After I had the suspension rebuilt I was going to take it back over to the trans shop and have them work on it some more, but when I said I was going to do that they said they had done all they could do.
