would a TPS cause the throttle to stick on 1987 7.4 tbi ?
blkgmcv3500
maine
william
v3500
Doubtful. Probably a gummed-up butterfly shaft.
gmbellew
Kansas city
glen
suburban 1500
yeah, likely not the sensor if the actual throttle is sticking open. if the voltage is sticking or being weird, that could be the sensor
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Sticking aic. Or iac can make it stick high idle. Or make it die in stop and go.
On a multipoint efi ford I had a bad tps cause bad high idle issues.
gmbellew
Kansas city
glen
suburban 1500
yeah, if the TPS is sending off-idle voltage when you are actually idling, it messes with the computer and causes idle issues, either rough or high bc the IAC will be either too open or opening and closing if the voltage is jumping around.
ehernandez
