Wire colors for 87 aldl
Mack Attack
Montville Ohio
R30
Hi guys,
I have a 1987 R30. Last weak when I drove it the engine light came on, then went off.
So tonight I thought I would hook up my code reader.
But I then noticed the four wires, where not going to line up with the pin connector.
Someone removed the wires, and did not put them back in the correct order.
Can someone tell me what color goes where??
I have;
Black /White Strip
White/ Black stripe
Brown
Orange
I REALLY appreciate only help Thank you!
I found a lot of pictures in a google search, but none with the wire colors listed. Maybe when it's daylight, someone can take a peak under their dash and solve this little issue.
CSFJ
I'll try to remember to check mine when I get home this afternoon.
BowTieJockey
Tallahassee fl.
Trey
I'll try and check mine when I get to work
Sent from my HTC6500LVW using Tapatalk
BowTieJockey
Tallahassee fl.
Trey
view: as if you were sitting in the driver's seat
View: as if you where laying under the dash with your left on the passenger side of the truck.
My truck is an 87 k or v10 whatever you prefer to call it. It's a factory 350/700 truck if any of that matters.
CSFJ
Yep, just like his pics. Top row only, from left to right; tan w/black trace, orange, empty space, black, white w/black trace, black w/white trace. As seen facing the connector from the drivers seat.
Qwk
Cincy
Craig
5.7/T56
I just removed mine last night from my 87. Ill snap a pic for ya when I get home.
Snips71
