Wiper motor turns continuously in the same direction
Charlie7985
Decatur, AL
Charlie
My windshield wiper motor is turning continuously in the same direction instead of turning back and forth. I've changed out the motor and have a new switch. Any ideas?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
That's how they work. Its the linkage that causes the direction to change.
Charlie7985
Decatur, AL
Charlie
When I installed it the wipers just kept trying to go down past the point they were able to, even after I changed the position of the arm that bolts onto the motor shaft.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Will the motor park when you shut them off? If not, you may need to clean the park switch. Ifs a 2 wire connector ( purple and gray I think) that is easily removed. Once you get the motor to park correctly, bolt the pivot linkage to the motor with the wipers in the park position. Hope that helps b
Snoots
Roger
Jimmy Sierra
You may need to remove the arms and re-position them.
Big Chip
Michigan
Kevin
C35
MrMarty51
Eastern Montana
Martin
Welcome to the forum 7985.
Try as Matt69olds suggested then reply back Your finding please.
Charlie7985
Decatur, AL
Charlie
Sorry for the late update. I ended up taking the wiper arms off so that I didn't have to deal with them binding up trying to go down through the cowl and I could see how the mechanism was operating. Noticed the they were turning down then up, instead of up then down. Removed the linkage from the motor, turned the linkage 180 degrees and reattached. Works fine now. Thanks for the help.
504SquareBody
