Redfish
- Nov 6, 2021
- Prairieville, LA
- Andrew
- V1500
I am In The Process of replacing my window felt on the passenger side. It is NOT going well. Disassembly went fairly well but getting the new felt to slide down the track between the glass and the track is proving to be impossible. Yes, I have sprayed the rubber with silicon lubricant.
I watched two different YouTube videos and both of them just went back in easily.
I am Very Irritated that the "Search" function on this forum is not working for me, I get "OOps a Server Error. Try again later". The information was a major reason I joined this forum and if it doesn't work...
I am probably less tolerant since it is about 95F and 85% humidity outside right now.
Does anyone have any suggestions to make this re-installation work?
