will these tires and rims fit?
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
Hey guys i was wondering if these rims would fit since I'm ordering online and don't want to mess up. They are 16x10 with -34mm offset. And 4.250 in backspacing. I want to mount some 245/75 on them. To run on a k20. I currently have 33 12.50 on 16.5 rims. Would those work? Thanks in advance.
Rims should fit fine, but a 245 tire is a bit narrow for a 10 inch wide rim.
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
What size would you recommend? I want some tires for dd use. Would 265 be better?
265 would be OK. If you want to stick with a tire similar in size to what you have now, you would want a 305/70/16. It could cause a little rubbing though with the wider wheels, unless the truck is lifted a little.
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
I'll probably go with the 265 then since I'll keep my other wheels for when I do heavy off roading. I want something for just daily driving with good highway tread
504SquareBody
