will 79 interior work in an 83 cab
Craig794x4
Claveland
Robert
i think it will work but what do yall think 83 air controls and gauges with 79 dash and door panels with 83 doors
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Door panels may be a little different, and the dash pad is made a little different but attaches the same. Otherwise everything should be really similar. You may run into some wiring issues if you use the 83 instrument cluster with the 79 harness. May have to move some of the wires around in the connector.
Craig794x4
Claveland
Robert
i have tracted down the problems im going too use the 83 hardness but im goin back with the 79 single headlights front clip and cut the head light hardness and make then work because im goin full power window and locks
the cab i bought is a 83 its complete wires doors glass everything
crazy4offroad
Curt
K-10
350/SM465/NP205
Man I dont envy you. I can do wiring but I dont like messing with it. About like doing house plumbing.
Craig794x4
Claveland
Robert
true but the cab i have is 2 wheel drive im goin 2 fiqure out to make the 4 wheel lock light out of my 4x4 cluster and put it in my 83 2 wheel drive cluster soo ive got my work cut out
Stroked
Beloit, Kansas
Jared
Yikes. You have more patience than I do. If it was down to something like that for me, I would just get a new wiring harness. Lol. I actually enjoy a little electrical work, but not that much.
As far as the interior goes, C4 pretty much summed it up. I'm not sure the door panels will interchange though. Someone else on here will know for sure.
Sent from my iPhone 4s using Tapatalk
The door panels will work, but you have to use the matching handles and support brackets for the armrests.
Craig794x4
Claveland
Robert
so when i order my door panel get everything for the 79 the wiring dont worry me i want it perfect as i can do it
Swims350
Logan WV
none
I also think the window regualtors are different, and to be right they need to match the door panels. Reason? the arm is longer on the newer trucks. They sold us an older shorter stub reg. for our 84 and it works but the door panel is sunk in around it. I forget when the changeover year was. it could be 73-76 or so for the short one and then 77 or 78-87 on the long stud.
I would use the 4x4 cluster, I think it may work not real sure I never messed with them much. of course you know about the trans hump/tunnel being different right? that's pretty easy though.
Damn that's a lot of work. :popcorn:
Craig794x4
Claveland
Robert
trans tunnel? am i going to have 2 cut the 83 out and put the 79 tunnel in?
Swims350
Logan WV
none
yes 2wd has a low hump floor and 4x4 has a high hump.
now if the 2wd is floor standard shift then it should be high hump and work fine.
pretty sure it's like this...
all 4x4's and then 2wd floor shift manuals=high hump
all 2wd autos and column shift manuals=low hump
It may be all manaul shifts have high hump, not really sure anymore. LMC has it listed though for buying carpet.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Check the cluster before you change it. My C10 2WD cluster has a 4x4 light in it (found it when trying to figure out which light was the choke light by shining a flashlight through the bulb holes).
Craig794x4
Claveland
Robert
thanks guys im so glad i found this forum yall are lots of help
mikejeden
