Why does my door have slop?
87ChevyR10
Kansas
NA
NA
NA
So, a couple weekends ago, I finally got the newish door pins to fully seat. Even though the door cleanly shuts, it has slack/slop in the door latch. It's not an issue until I hit bumps and such, then it sounds like I didn't shut the door completely. The striker doesn't have the plastic bushing or whatever it's called on it. If I put a pex one on, would the take away the slack? The bottom rubber door stop is still in place, too.
Ideas?
DanMcG
Central NY
k10 k10
do the trick with the pex, you'll be surprised what a difference it makes.
glockholiday
Jeff
V10 Suburban 1/2 ton 4x4
When I put the plastic tubing on it made it soooooo much better to close and latch the door, no more slamming. But my door still rattles a little too over bumps and my pins are tight.
Georgeb
Wisconsin
George
K10 Burb Z71
Replace the door weatherstrip and adjust your striker so the door is tight.
glockholiday
Jeff
No argument on the weather stripping but how do I adjust the striker?
Georgeb
Wisconsin
George
K10 Burb Z71
Draw a circle around it and then loosen it up with a torx bit from the end. Move it towards the insde a little.
glockholiday
Jeff
I've been reading about it since our last post and it seems I could drop the nut inside the door frame? And mine being a Suburban I'd be extra screwed is that right? Pick ups have a removable panel? I know I would only need to back it off half a turn or so to move it but I'm just not sure since I don't know what it looks like on the inside of that striker.
Georgeb
Wisconsin
George
K10 Burb Z71
I think you can drop it but you won if your only going a half turn. Not sure if it is captured on the suburbans or not.
joecal
LaGrange Highlands,IL
Joe
C10 stepside
305ci
If you just loosen it a little it should be fine for the adjustment. I don't think the nut ( I think it's a metal plate)would fall off. I agree with installing the plastic piece, mine were missing too, and it made a big difference. I had to slam my driver's door to shut it when I got the truck, now it shuts with very little effort.
guillermoariast
