- Apr 11, 2017
- kansas
- Rick
- c20
Okay I'm going crazy trying to figure this out 1986 carburated 305, 700 r4 truck. The pigtail to the egr bleed solenoid is destroyed, so simple fix get another pigtail wire it in.Now here is where it gets complicated.The truck is non lockup th350 swapped.So being the bleed solenoid is controlled by the transmission circuit would it be inop anyways if I replace the pigtail.What is the bleed solenoid actual function does it bleed vacuum to keep egr from working in lower gears?Or bleed vacuum so egr doesn't work with converter locked.Goal is to get the car working.
