which rear will bolt up
bigun
georgia
joe
I have a 85 c20, 4 speed and a coporate 14 bolt SF rear end that may need to be replaced it makes a pinging noise when you go back in the throttle after slack in the driveline, what later model rear ends will work with minimal mods?, I'm a welder/fabricator, so I can move perches etc. thanks for any help
Georgeb
Wisconsin
George
K10 Burb Z71
You sure it's not a u-joint?
87scotty
Central il
Andrew
V20
5.7 for now
If I'm not mistaken thats a pretty good rear end rebuild or find another?
bigun
georgia
joe
u-joints are tight, rebuild is about $700-800 that I don't have and newer ones are easier to find but not sure if they'll work, that was the reason for the question
Sounds like a sticking/seizing u-joint... so it might still be tight.
If you can move perches, you can use pretty much any full size truck axle you want. Newer body style trucks tend to have a wider housing, since the wheels keep getting more and more backspace.
Georgeb
Wisconsin
George
K10 Burb Z71
It may be that what you are hearing is slack in the side and spider gears being taken up when you go from coasting to loading the driveline. I have had many trucks that did that for many, many miles. The noise is just amplified by the drive shaft. I would take the cover off and inspect for wear and excessive backlash before I jumped off the cliff. In fact my 78 c10 has almost a quarter turn of slop and has been that way for 16 years. I will admit it is worn out and needs to be replaced but I just need two more years out of it.
highdesertrange
kalifornia
mike
k30
bad u-joint, I don't care if it's tight you have a dry one. highdesertranger
bigun
georgia
joe
I took the cover off and gears still look good, you can move the drive shaft 1/8 turn or better before spider gears make contact, I assumed that was my noise, but I will recheck u-joints, thanks for the info guys
adamj
Colorado
Terrence
V20 Suburban
5.7L TBI
Question was never answered here: what is the axle swap compatibility?
I need a new rear end, I have the 9.5" 14 bolt, but going to rebuild so might as well find a FF14 bolt. Which axles swap right over without relocating perches? I have an 87 3/4 ton suburban, I'm fine with the 3/4 ton drum brakes, don't need discs.
highdesertrange
kalifornia
mike
k30
I believe any single rear wheel 14ff out of a PU or suburban will bolt right in. a van will not the spring pads are in a different location. just use a tape measure. highdesertranger
CSFJ
I thought there was a difference between 1 ton and 3/4 ton on the shock mounts also?
highdesertrange
kalifornia
mike
k30
on the duallies there is some one else needs to chime in for the singles. highdesertranger
adamj
Colorado
Terrence
V20 Suburban
5.7L TBI
I read that the "pinion snout" on the 14BFF is longer than the 14B sf, so I would have to get the right driveshaft too... I think I'm going to stick with the SF 9.5", I don't off road that hard anyways, just some light towing of a pop up camper.
So any 9.5" will mount right up? Shock mounts too line up?
From 81 up to when?
CSFJ
Yeah, the semi-float was a 3/4 ton only axle. As long as it came in a square body, it will bolt right in. As long as the gearset matches (if you have 4wd)
ALL the 1-ton trucks got narrower perch spacing and relocated shock mounts, even if they were SRW. This also applies to the uncommon crew cab C20.
derek87
