Which manual transmission?
m1028cucv
california
john
k30 (m1028)
Hey guys, I have a 1986 m1028 cucv and I want to do a manual swap there is a “indent” where the shifter would be. I would like to use a sm465 but there is no overdrive and I would like for the shifter to come though or close to the stock location if that’s possible. I know I’m gonna be grilled for say this but the getrag g360 would come close I think and I don’t think the 6.2 has enough power to break it so I read. If it’s really not a good choice I’ll got with a nv4500. If you guys know of any other transmissions please let me know. Thanks guys
What application was/is the G360 used in?
'89-'93 ? Dodge w/Cummins oil burner.
Adapting the input and output for Chevy use is probably expensive or not possible at all?
Turbo4whl
Downingtown, PA
Wayne
My '98 Hobby wrecker has the NV4500. Yeah I may have gone past the GVWR of 15,000# but I haven't broken it yet. Would be a much easier swap.
Here is some info, I missed the synchronized reverse by one year:
NV4500 (click)
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
V10 Suburban/V1500 Suburban/M35 bobbed w/dump/M1010
5.7/5.7/LDT 465-1c/6.2 diesel
I'm looking at the TR-4050 for about the same application.
Not cheap but they are still building them and they can handle the torque of a 6.2.
SquareRoot
This is an easy one.....NV4500. Cuz I just done it. As for durability, that trans could stand up to 3 of them old rod knocking 6.2's. If you go this route, I can answer all your questions. Converted my 85 K20 from slushbox th400 to manual trans, hydraulic clutch with all the good tips and tricks.
BKING33
York Springs, PA
K30, Suburban
6.2, 6.2 turbo
I'm running a NV4500 in my daily driver Burb. It has a 6.2 with banks turbo.
Wouldn't go any other way. Get 20mpg and can cruise 70-75 easy with 3.73 rear gears.
boltbrain
Montana
Chevy K20
Is that a 4 wheel drive? I have a NV4500 I can put in my 79 K20 which has 4.10 gears but I’m checking to see if I can convert my 14 bolt to 3.73, and heard the front Dana44s can be converted by just swapping axles.
SquareRoot
You don't want 3:73 gears behind that 4500. Trust me.
Washington
Agree.
@boltbrain , look at the rpms you'll be running in 5th gear with 4.10s.
With 32-33" tires, you'll be close to or a bit over 80mph at 2500rpms in 5th gear.
You have the cruising gear in the trans, don't need to double down with higher ratio axles.
BKING33
York Springs, PA
K30, Suburban
6.2, 6.2 turbo
No, it's a 2 wheeler running a 265/75R16 tire. Depending on your tire size, you can still run the 410 rears just fine with a NV4500.
Kipps5000
