Where to measure to see if truck sits level
Vetteman61
USA
I just installed a 3" lift on my '87 K5 (springs front and rear). The rear looks lower than the front, and I'm aware that the higher fender wells in the front can make it appear it squats in the rear even when it doesn't.
I just measured the body line above the rear taillights, but I'm not sure if that's a good spot.
Where do you measure you trucks to know for sure if it's sitting level.
-Brandon
Camar068
10 yrs Air Force
I wanna say bedside, but I'll let the pro's give you an official answer.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I've always measured to that body line above the rear taillight.
I always measure the lower rear corner of the front wheel well, and then the lower front corner of the rear wheel well.
All body lines have a taper, to some degree. While the lower fenders, rockers and lower bedsides may not always line up perfectly, if the truck body were to be sitting directly on flat surface, those areas would be level with the ground.
mikejeden
