what is this liquid and why?
MadOgre
NA
NA
NA
NA
NA
The set screw by itself seals it from leaking just by the fact it is threaded then you add epoxy to the threads and it will never ever leak again
EDIT: I should add that also the epoxy between the threads will not come into contact with the fuel which is also an added benefit
Georgeb
Wisconsin
George
K10 Burb Z71
I have tried the O-ring plugs myself without success.
MadOgre
NA
NA
NA
NA
NA
Ok, so how would I troubleshoot it? :) I'm open to suggestions!
Take off the carb and if the fuel well plugs are wet and dirty they are leaking if they are nice and dry then they are not. It could be that you have leaking fuel well plugs and it is leaking from the fuel inlet area as well. Be observant . look closely for signs. Your eyes are what will find the source so look carefully.
Ps don't just take the carb off and turn it upside down to look at them as all the fuel from the float bowl will come pouring out all over you and every thing else too
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Smell it. Start there.
mistaake
SF Bay Area, California
Michael
Crown Vic
If I take that carburetor off I guarantee I'll mess something up.
flyboy1100
UsA
me
k1500
Just a few linkages and bolts. Take good pics first
MadOgre
NA
NA
NA
NA
NA
Go slow !!!
starlinstephens
