What is it?
CRM
Pasco, Washington
Casey
K2500
350 CI
Found it behind the seat when I pulled it to replace the upholstery.
Fastereddie
Nevada
Eddie
I think it holds the sound deadener pad to the firewall down by your feet.
CRM
Pasco, Washington
Casey
K2500
350 CI
I'll check it out tomorrow.
74 Shortbed
Yep, that's what it is.
chengny
A little tip about these fasteners - lesson learned:
If you intend to reuse them, don't try to yank them out from inside the cab. Give them a little drink of WD-40 and push them through the FW from the engine side with a pair of needle nose. They are pretty weak after all these years and they break easily:
CRM
Pasco, Washington
Casey
K2500
350 CI
Thanks guys. I'll find out where it's supposed to be and reinstall it tomorrow.
spartantx117
