What does this sound like?
agers20
Justin
305-V8
Hello all, I have a 1984 c-10, bone stock w a 305. I don't know what type of transmission it has, but it's giving me problems. I drove it back from the mechanic for unrelated issues to the transmission except for having the u-joints replaced, and it drove like crap. I don't have the bed on it, so there's very little weight on the rear end of the truck. But it wouldn't get above 45 mph and it shook like hell every step of the way. It has no traction whatsoever. the trucks idling super high, so you don't need gas when you put it into gear. Whatever you select, it's going to burn out and haul ass up to 45 mph or so. I'm wondering if I need to flush the trans and refill it with the correct fluid because before this time, it had sat in a field for 6 or so years. I'm wondering if it's overfilled with fluid. I think there are multiple issues at play here, but I'd like to sort out the trans so I can at least drive it up and down the road. Also, what is the stock trans type? Thanks for any help!
The88
Mhmm
South Louisiana
ThatGuy
If you want to know about what tranny you have drop under and look at the pan. Then Google "identify chevrolet transmission". That should let you know what you have under the truck.
As for running rough and high idle I would check all the basics first off since it was sitting so long ex air, fuel and fire. If those 3 things are good to go start looking at stuck parts that could allow excessive air in at idle. Stuck butterfly or vacuum lines. It shouldn't be to hard to figure that one out.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yeah, you definitely want to go through all the vacuum stuff on it. Anything that fell off or rotted is not gonna help you. Ignition cap and rotor might have corrosion, plugs might be fouled. If it sat a long time, the carb could be in pretty nasty shape inside and need a rebuild.
agers20
Justin
305-V8
the capt/rotor, plugs and wires are brand new. im worried about the vacuum stuff,, some of it's plugged off..
agers20
Justin
305-V8
These are the pictures I took. I can see why it might bind up some as the transmission cross member bolts on the driver's side are missing completely. It's a good 2-3" lower than it should be. I'm going to order some of those today and hopefully have them in soon.
highdesertrange
kalifornia
mike
k30
for sure you have several issues. you need to pick one thing and start from there. I would bolt up that cross member and get the minimum vacuum working, that would be the vacuum advance and the modulator on the trans, plug the rest. if that doesn't correct the idling high check that next.
the shop didn't offer any insights?
highdesertranger
78C10BigTen
pennsylvannia
C10 BIG TEN
highdesertranger
I agree on gettin that x member bolted up tight!!! Look how far its off!
78C10BigTen
pennsylvannia
C10 BIG TEN
My x member was tight but the bolts fell outta my trans mount and damn did that make noise on xcel!
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Hello all, I have a 1984 c-10, bone stock w a 305.... It has no traction whatsoever. the trucks idling super high, so you don't need gas when you put it into gear. Whatever you select, it's going to burn out and haul ass up to 45 mph or so.
Are we being punked?
A stock 305 with vaccum leaks doing burnouts? Let alone a continuous one.
agers20
Justin
305-V8
I apologize for the severely late reply. maybe I should paint the picture better. It doesn't have a bed on it at the moment. So there's no weight pushing down on it, so it just spins easily and continuously. it shakes, rattles and rolls, and none of those are impressive by any means. I didn't mean to imply it's some hp monster and puts down power.
80BrownK10
Greenwood, SC
Nate
Don't order bolts just go to Lowe's or you local hardware store or Tractor Supply Co and buy some grade 8 bolts. Have it done in a few hours total. (Counting going to the store or two).
nr9016643
