What does Rough Country Recomend
87silveradok20
Ohio
Levi
Silverado k20
I was wondering what tire sizes and wheel offset RC recommends for a 4" and 6'' lift
87silveradok20
Ohio
Levi
Silverado k20
so can you guys answer a question or not
MadOgre
NA
NA
NA
NA
NA
Any size you can fit under the wheel wells. Even if that involves a sawzall :)
87silveradok20
Ohio
Levi
Silverado k20
but i dont want to involve a sawzaw on my truck, if it were a wood/mud truck maybe. but nor on my fancy truck
A lot is based on opinion. Are you willing to trim at all? Do you still want decent ride quality? Do you prefer wide wheels/tires or a little more narrow? Do you like the big lift look or the stuffed tire look?
87silveradok20
Ohio
Levi
Silverado k20
i like stuffed tires and i would perfer to not trim
350runner
tx
Ceasar
I too like the stuffed look here is what's possible 33x10.5x18
That makes it a little more difficult.
With a basic 4 inch lift that is not very soft, a 35x12.5 on an 8 inch wide rim should fit with no or very little trimming. But if the springs are flexy at all and the rims are 10 inches wide, you may want to stick with 33's.
87silveradok20
Ohio
Levi
Silverado k20
ok thats what i thought i may do a 5" lift front/ 4" lift rear and 35s, that should clear right?
87silveradok20
Ohio
Levi
Silverado k20
this is what bds recomends so you think this will fit? 35" x 12.50" w/15 x 8 and 3-1/2" back spacing
bluex
Spartanburg SC
C15
Have you called rough country to ask them? You can download installation instructions from there site an in them it lists recommended tire sizes. At least it did in the kit for my 98...
Like I said, it depends on the springs. That setup will require at least a little trimming on the front fenders. Rough Country springs are a little more firm and trimming might not be required.
87silveradok20
Ohio
Levi
Silverado k20
OK Thanks
Grumpy Grizzly
Kalispell, MT
Josh
Suburban 1500
I know when I looked it for my ride the back spacing should be 4.5, other wise you will rub on the turns.
With the 4" you can run 35" tires street and 33" for off road.
With the 6" you can run 37" street and 35" off road.
So if you are running it as a mall crawler then 35" will be fine for this application and you will get your studied look.
Also the springs do make a difference and you will want to go with a 35x12.50 R 15 on a 10" wide rim so you can have some wiggle room in your fender wells.
If you run a 12.50 tire on an 8" wide rim you will end up wearing out the center of your tread too early because it will bubble your tire too much. Now you can get away with it if you run the tires at a lower pressure but I wouldn't recommend this. It also can cause issues with your side walls as they will be bowing in towards the rim more than the tire was designed to do.
Ls85c10man
