Wanted! Drivers side lock rod
89k5Blazer
California
Meg
K5 blazer
V8
Anyone have a drivers side lock rod for sale? It’s for an 89 k5 blazer
* Not sure if that’s the correct name for this part
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Im unsure if blazers and burbans are the same and how the rod removes but ive got a late 80s burban in our yard at work that may have one.
89k5Blazer
California
Meg
K5 blazer
V8
I only removed the door panel to check out what was going on. The lower end was still attached it looked like it had a loop on the end and was maybe held by a metal clip. The door still locks so I didn’t mess with anything yet. I’ll remove the other half in the morning
can you show a diagram of how it works on the door i may have some
89k5Blazer
California
Meg
K5 blazer
V8
It’s #22, it’s for the push/pull knob that shows when the door is locked or unlocked...
I knew that but I didn’t know how it articulated with he rest of the door. Perfect. I can check but I think the rod is.. plastic. I had a handle set in a pile I’ll check.
89k5Blazer
California
Meg
K5 blazer
V8
It’s metal, I posted a previous picture of the top half of the rod that broke in half with the screw on lock knob next to it.The bottom half is attached to a lift actuator. I planned on removing the attached bottom piece but it rained today so it didn’t happen.... Thanks for taking the time to look and respond!
johnalen76
