SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- Rob
- C20
Ok most of your questions I've already talked about before, but it is probably in the spark plug fouling thread not this one. So Your questions will be in yellow, my answers will not.but 5 and 7 are next to each other
A guy can switch those wires on the cap and not notice.
Coincidentally 5 and 7 are next to each other at the intake manifold and there aint much gasket separating them...wasnt much 40 years ago anyway..
Does the EGR even work?
Didja test it with a vacuum pump?
Didja try re-introducing the crankcase gas via the pcv valve? The carburetor needs that vapor mannnn...
Remember Smokey Yunick made that fancy manifold?
I think we're barking up the right tree but i'm starting to wonder if you havent made these troubles for yourself , dude.
Was it 5 and 7 or 4 and 7?
#1. "Does the EGR work." Well yes the valve itself works, the passages in the intake are plugged. Exhaust will pour out of the exhaust port in the manifold with the EGR valve removed and the engine started. However there is no vacuum on the intake side of the EGR. Hence the ports in the manifold are plugged, as in with carbon.
#2. "Did I test it with a vacuum pump." No. When I bought the truck 4 years the EGR had been removed and a block off plate installed, so I purchased new EGR valve see #1 for why the EGR system is not working.
The PO, was a really good guy and took care of the truck in general but as he got older and his health got poor he did somethings that weren't necessarily the best, anyhow for whatever reason the EGR was blocked off and the vac advance disconnected. I'm not going to recount the entire thread here but to paraphrase the ESC system needs a new knock sensor. The old one is frozen in the block. I know what I'm going to do to fix it but not going to unless I can get the plug fouling / miss fixed. So running with the vac advance disconnected keeps it from pinging even thought the EGR and ESC are non-functional at the moment. I understand that's not right, but it's better than pinging the motor to death.
#3. "Didja try re-introducing the crankcase gas via the pcv valve? The carburetor needs that vapor mannnn..." Maybe I wasn't clear earlier it was late and I'd had quite a bit to drink by then, but PCV was only blocked off briefly during testing. The engine is and has always been run with a fully functional PCV system.
#4. Remember Smokey Yunick made that fancy manifold? Ya.
#5. "I think we're barking up the right tree but i'm starting to wonder if you havent made these troubles for yourself , dude." I doubt I've made these troubles. But you might have. Your location seems to be my Mom's house, and you have been there for quite a while, so if your there you probably know where I live came over and messed with my truck. For the record your not the first person to bring up the intake thing, I've just been really hesitant to believe that's the problem since it passes testing.
#6. "Was it 5 and 7 or 4 and 7?" Your talking about 5 & 7
