Valve Body Help please!
garzas23
Brazoria County TX
AJ
First, i have a th-350c and have installed a transgo shift kit. My reverse was acting up. When i put it in reverse it would bog the engine then studder and die. But the forward gears worked perfect.
So i dropped the valve body to find the little piece (reverse boost valve) had slipped out of the aluminum boost valve sleeve and was slideing back and forth freely in the valve body cylinder. My question is, is it supposed to stay in the sleeve? And how? It seems that nothing is to stop it from moving around.
garzas23
Brazoria County TX
AJ
Also, the transgo reprogramming kit came with the option of 2 springs for the pressure regulater valve, red or orange. It says the red is for street and heavy duty towing, and the orange is for competition. So has anybody ever used the orange? is it to hard of shifts? and will it cause long term damage?
garzas23
Brazoria County TX
AJ
Fixed It!!!! It was the small reverse boost valve in the pic afterakk. I installed it correctly with the orange spring in the pressure regulator cylinder from the transgo kit and it working great!
