Vacuum question 1986 K5 350
Horn Hunter 62
Kingston, Tn
Randy
K5 Blazer
I just bought an 86 K5 Blazer with a crate 350 that was installed in 2021. It was installed with headers, so the smog pump, canister, etc., was all deleted.
I found some vacuum lines missing.
1.The tip in vac switch
2. The TCC switch (which I think was originally connected to the canister)
3. The Vacuum ball to the right of the brake booster.
So, can all 3 of these be T'd to manifold vacuum?
Does the TCC need a delay valve as shown when connected to the canister?
Also, what is the red metal vacuum looking canister to the left of the brake booster? And where did that broken vacuum line go?
Thanks!!
longbeach
Maine
Wayne
I'm not sure about others. But, I believe the red canister was for cruise control. The front half of that should be rubber.. There is an adjustable rod that goes from that clip on the front to the carburetor linkage.
Turbo4whl
Downingtown, PA
Wayne
I just saw this post, welcome to the forum.
59063_0900c1528006c5e5_122_477lo-jpg.7458
The converter lock up switch should get vacuum from thermal vacuum switch. (TVS) This is so the converter will not lock when the engine is stone cold. Cold engine low throttle, low MPH, if the converter locks may cause the engine to bog a little. Still best to have vacuum to the Trans conv. vac sw. with out the TVS, then to not have it at all. Never having lockup is not good for the transmission.
stefanchevy10
new york usa
stefan
did anyone else reply about the first photo and other photos
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
The big brake booster hose should be connected to the big port on the bottom back of carburetor. The one to trans should be manifold vacuum port usually behind carburetor on manifold. The black ball is cruise control. Idk about the other Grey cannister.
1lejohn
texas
john
k-1500, 2500 HD
What transmission is in the truck. If it's not a 700 then most of the vacuum sensers going to the transmission can be remover or capped.
The red cannister is for cruise and the linkage is missing anyways,so ignore. You've been answered about the convertor switch. The other component on the firewall is for tip in. Look at your distributor does it still have a wire harness plugged into it that goes into the firewall and disappears behind the glove box? If so your esc is still hooked up the tip in switch needs to be connected to manifold vacuum. The hose in your left hand,needs to be connected to your right hand,or you need to give us a little better idea as to where it comes from a hose in mid air could be just about anything.
630erik1
