Turn signals not working.
Erik Anderson
Connecticut
Erik
GMC K25
1975 GMC K25. All the lights work, hazards work, turn signals do not work at all. I’ve read previous threads on this issue and done some troubleshooting but hoping for more opinions. I’ve checked the fuse that controls the turn signals and the reverse lights and that is good. I have power on both sides of the fuse. Hazards work fine. And I have swapped the flasher for the turn signals and hazards and the hazards still work and turn signals still do not work. When I check for power at the flasher I have none on either side with the turn signals on or off. Any ideas? I’m hoping to not have to tear into the column.
dvdswan
Port Orchard, WA
Dave
I'd check the turn signal switch itself.
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
just got done with this problem my self. It was the turn signal switch. That switch controls a lot of functions with your lights.
Erik Anderson
Connecticut
Erik
GMC K25
So I read to test the turn signal switch to unplug the harmonica plug on the column under the dash and test for continuity between certain wires for the left turn and the right turn and it appears that the turn signal switch is not my issue. I don't know where to go next
86sunnyguy
