Turbo 400 won’t do anything
77truck
Enumclaw
Jake
hi I have a 1977 c10 with a 454 and I put a turbo 400 behind it. I went to drive it and nothing won’t go into any gear or move at all. I changed the vacuum modulator. Checked my vacuum on it. Swapped torque converters. Checked the governor gear also put a new valve body in it and still nothing. Any thoughts?
86Peter454
Missouri
C10 Scottsdale
wont go into any gear as in physically you cant change the gear or when you move the lever to drive it just doesnt move anywhere?
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
4x4k20
ga
johnny
k3500 k20
when you put the t400 in did you make sure the torque converter was in like its suppose to be? if not it will not move the front pump may be broke.
77truck
Enumclaw
Jake
I did make sure it was seated it clicked the three times. Unless that’s wrong
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Sounds like a front pump 100%. Get a pressure gauge on there if you can, that'll be the final word. A good rule of thumb is that you shouldn't be able to stick your fingers behind the converter
77truck
Enumclaw
Jake
When you move it to drive it won’t go into any gear at all just stays constant in neutral. So I disconnected the shifter and tried moving it on the transmission and still nothing
77truck
Enumclaw
Jake
If it is the front pump can I just replace the front pump or do I have to rebuild the whole transmission?
djisurfli
