Trim clips needed
waterpirate
delaware
v10
5.7 tbi
So as the re assymbly process continues, I have a list of lost parts! lol I need a source for the clip/bolt studs that hold the trim piece to the radiator support and also the the slide in clips that hold the fender trim to the trim on radiator support.
Thanx in advance
i have zero idea of what you seek
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Thanx in advance
I may have what you need. For what years? I'm assuming 81-87.
I have 3- 80s core supports that I could rob of there trim clips. Let me know.
The grille and bezel surround trim?
I recently found out that the little studs went from plastic, to metal at some point.
waterpirate
delaware
v10
5.7 tbi
So when I got home today I got off the interwebs and got out the lmc book. The clips are listed for the piece that connects the fender trim piece to the grille trim. If it is in stock, I am in like Flynn. If not I am shopping used from above.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
I do.
I believe he needs these...
The clips that hold the grill trim to the core support.
Chevymania09
Jason
350 ci
Hello, I have the new left hand headlight trim piece that has 2 of these already attached. But, my fender only have slot where the pinsvfit in, no clips of any kind. Do you know what type of clip i would need for these smooth pins to go into and lock onto the fender?
So what the clip above posted by aywoch then pushes into?
waterpirate
delaware
v10
5.7 tbi
So the clips posted above were the clips that I was after. I posted up in "score from u pull yards about my luck getting them"
Kelly78K10
