Transmission Indicator Cable
McCSquare
Champaign, IL
I'm not sure what it's called exactly - the orange pin that indicates transmission gear position. I went to replace it today and I realized that the issue was the cable wasn't hooked up to anything. I've been searching the shift column and haven't found anything. Where do I hook the cable end to?
It just hooks to the sleeve on the column, the sleeve rotates when you move the shifter.
chengny
Look for a little scratch mark to help set it exactly where it was or else you end up with one of those position indicators that points to N when you are in D.
If you cant see a scratch mark (and stuff like an skewed gear indicator bugs you) take my advice - don't jam the clip completely home at first. Run the gear shift up and down a few times, maybe even drive around for a few days, to make sure it reads correctly. The push it on all the way.
McCSquare
Champaign, IL
My problem I think is that there must be a pin/dowel missing on the cluster. If I hook the cable directly to the column the pull on the cable is straight down and it binds and won't get past OD.
chengny
I'm not familiar with any type of a pin to make the cable change direction and turn downward. All I've seen is a extra lobe with a slit in it that the cable passes through. It is way over on the right side of the indentation - actually it looks more like a crack in the extrusion than a fairlead. Some photos to help:
McCSquare
Champaign, IL
Ahhh. That's the secret. That little groove changes the direction so it pulls properly. It looked like a cracked mounting tab to me. Thanks!
starlinstephens
