Transfer case issues
MrSuburban
rockford
jim
i dont really know
suburban
Ok so here it is. I have a suburban with what looks to be a np203 with the fill hole just to the right of the rear drive shaft. When you hit the gas it rumbles and as your slowing down it sounds like something is clanking. When i got under my truck there is spray on the under body. I cant tell if it cam out the back of the tcase or it its from the u joint. Whats the best way to test this? Will removing the front drive shaft stop the rumbling? thats the only way i can think to test it is to remove the load. any suggestions??
Guardian
Jeff
c 10
Sounds like an internal issue with the gears or chain. I am not familar enough but one the the 4 wheeling guys will help you out, hang loose for a bit.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Check the mount bolts first between the t-case and mount. Mine were loose once and it was raising all kinds of cain. You can also drop the rear driveshaft and try to turn the output yoke and see if you can see/hear any excessive play in the chain. Make sure you have a 203, post up pics if you aren't sure.
keithosman
