- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
We've discussed this a fair amount on some of the builder sites and forums and honestly your towing capacity is legally limited to whatever the GVWR rated capacity of the vehicle is. If you have upgraded the engine, and drive-train it does not increase the strength of the frame or it's capacity to haul, tow, etc etc and that is what determines your tow rating in the grand scheme of things.
Imagine taking your k30 4x4 crew cab and doing a Cummins swap with all the accouterments and finding out you are still only allowed to tow the limit of your k30 chassis. That is what guys are running into now though, so just to inform you that if you go beyond the legal limit you will suffer the wrath of the police if they suspect you are running heavy or overloaded.
It probably varies by state, but as far as a commercial vehicle in Ohio goes, you can simply buy a higher weight rating.
