Torque specs on gm 10 bolt
87scotty
Central il
Andrew
V20
5.7 for now
I'm changing bearings and seals in the 87 just hoping.for some specs don't have my chilton
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Carrier and pinion bearings and pinion seal? Or axle bearings and seals? All the above? 10-bolt rear or front or both?
87scotty
Central il
Andrew
V20
5.7 for now
14bolt rear I've already done! Doing both front wheel bearings
The first nut goes on by feel. Snug it up and back it off a few times, then tighten it to get a slight drag on the rotor. The second nut gets tightened as much as you can without the socket slipping off.
87scotty
Central il
Andrew
V20
5.7 for now
10-4
87scotty
Central il
Andrew
V20
5.7 for now
Anyone have a pic or place to see all the parts in order had a lil metal and a plastic spacers
crazy4offroad
Curt
K-10
350/SM465/NP205
There's a plastic washer that goes on the axle stub shaft before the hub assembly goes on, and a little rubber seal on that. Then there's a metal washer with holes in it that goes between the spindle nuts, it should have a tab that goes in the groove of the spindle. The 1st spindle nut should have a small dowel on it that you line up with one of the holes in the washer, then the spindle jamb nut goes on I think 150 ft/lbs which means pretty much tight as you can get it lol. Sorry I cant find the diagram of the exploded view.
87scotty
Central il
Andrew
V20
5.7 for now
No problem thanks for.the help
630erik1
