Tired of the screaming small block!
Clutch
Dirty Jersey
K30 Silverado crew cab dually
L82 350
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Wow I got confused I thought he was talking to me? I'm so not good at this forum stuff lol
He was. Lol let’s try to keep up lol you should get in on one when there are like 4 or 5 of us derailing the hell out of some waste of band width lol. Your thread is not one of those......yet lol jk
Clutch
Dirty Jersey
L82 350
I had a 78 Calais that had a 260 turd and I dropped in a 455 they will definitely let you know where the weak parts are in the rear suspension. Lol
I've got an 87 455 4 speed a 78 Cutlass W-31 350 350 auto and my 11 year old daughter has a hurst Olds 350 auto love those cars
74 Shortbed
So I guess any complete heads that are in good shape will work just clean up the bowls and tops of the runners ?
Lot more than that, look inside ports were bored straight corners are sharp and needs blending, chambers need work also and there's where you can dial in compression, lot of free torque available just need time to extract it..
Clutch
Dirty Jersey
L82 350
Ok I can handle that. My olds motors have an inherited problem on the exaust side I always fix the unwanted egr bumps my small block car I even ported the manifolds to gain some free power without running headers.
I guess I just need to find a set of heads and we'll use my head and a die grinder. Anything else I should know about BBC heads when I'm looking for a set?
74 Shortbed
Other than the usual, I take a straight edge with me to check rocker arm stud alignment, not a common issue but I've seen them off and that can jack up the geometry if they're too far off, they can be repaired but gotta take the cost into consideration when buying.
4WDKC
Southern Florida
Kacy
Is that a stock L82?
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
He's not kidding, it happens to my thread more often than not, but I don't mind, its a good laugh.
Clutch
Dirty Jersey
L82 350
No it's something someone piece together. L-82 block and pan 4 bolt main cast crank x rods Mexico heads Edelbrock Performer intake 80 454 Quadrajet 84-85 Corvette valve covers and a huge cam that should not be in a truck. I only know because a (Corvette guy) good help him looked over the numbers when I was working on it after I bought it
She has the look on her face that she's driven circles around daddy before!
Clutch
Dirty Jersey
L82 350
MikeB
North Texas
If your small block is in good shape, why not just put a stock-type cam in it, like a brand new take-out Goodwrench 350 cam? They are commonly sold by crate engine vendors like Pace Performance for $50 including new GM lifters. And if they don't have one, I do.
Of course, it would help to know the compression ratio and head specs. A stock-type cam probably wouldn't like much above 9.0:1, and large volume intake runners (above 185cc) could be detrimental to low RPM torque.
So, for a few bucks and a day's labor, you would have something that should work in the truck while building a big block.
Ah, just noticed the Mexico heads. More than likely they would be good to go with a stock cam. Also, they're probably killing cylinder pressure with the big cam, which contributes to the engine's lack of torque. But, hey it's got that rumpety-rump idle. :)
AzGeo
Since you already have the Chevy bellhousing bolt pattern, you can easily build a 454" BB with 550 lbs of torque with under 10 to 1 compression .
But if you have a "BOPC turbo 400", you will not find any better towing gas motor, than a 507 Cad, 9.4 to 1, 236/248 on 110 centers (@106), with a FITECH EFI (or any other cheap brand) , with an HEI .
EASILY over 600 lbs of torque in the 1800's to 5000 .
Clutch
Dirty Jersey
L82 350
A cam swap is a definite possibility I just don't want to devote the time to it with so much other stuff to do on the truck and I don't think it will ever make the torque a BBC with a RV Towing cam will. Yes that all wrong small block sounds lumpy at idle lol my neighbor jokingly calls it the race truck.good to know about cheap cams from pace performance tho I'll check them out on line thanks
Clutch
Dirty Jersey
L82 350
I think if I was going to go that route I would just use one of my spare olds 455s but the hole idea was a 454 would be cheaper to go threw than a455 plus my bell housing is Chevy so I'd need to build a trans to I just don't know much about BBC parts when I finde a set of heads for it I'll post the casting #s here before I buy them and see if the guys here think that they will work for me
reisman20
