Tire size advice needed!
Billyk20
3311 legends mist dr
Billy
Chevrolet C/K 20 Silverado longbed
5.7L 4bolt
I have 35x12.5r20 on there now in the picture but I have 17s that I’m getting restored and then wanting to put 37s as a swap out set. Would I need a bigger lifer or will it fit, I’m willing to trim the inside as much as I can but I won’t be cutting the corners completely off. Any advice will help thanks!
Washington
In general, for K20s I’d say 4” lift = 35s without trimming. 6”= 37s no trimming.
depending on offset and considering normal driving conditions. Not twisting it up on a trial.
JMO
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
My K5 had a 6" full spring Skyjacker lift and 15/36R16.5" Radials. Wheels were 16.5" x 9.75" with 4.75" BS. These would have rubbed if I didn't use the cut out flares.
yevgenievich
Viktor
sad
very sad
less sad
About 8" lift with 37. Fenders were trimmed when was running 38" tires
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
37s are pretty big tires. You might get away with it if you don't plan to use it offroad, and you may experience some slight rubbing if making a full lock turn, but for general use you could be okay.
Though either way, you 100% made the right choice getting rid of the 20s.
strokedK15
