thinkin bout a motor swap..
TJ79Cheyenne
Somerset, WI
Torrance
Well i figured my 79 out i think... Threw another reman'd starter in, hooked all my wires back up, reconnected the battery, and bam! Fired right up! I guess i win for now hahah
Thunder
Colorado
D.
So was the starter just bad or shorted out?
TJ79Cheyenne
Somerset, WI
Torrance
Brought the starter in and it failed.. threw a heat wrap over the new one just incase
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
A few hundred bucks? You can buy a new rotating assembly for that. I assume you mean for the shop to assemble the engine.
Send me a link or explain where to buy a fresh rotating assembly for under 500 bucks.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
He said a "few" hundred bucks. I guess it depends on your definition of few. I think Scat or Eagle offers one for the small block for around $650.oo. It's been a long time since I've played with small blocks.
Im usually a huge ********* on the internet after a few beers but im being completely sincere and honest saying this, Literally the last person to give me the speech about what a few means was a toothless ******* carnie. This was last weekend at a carnival I went to with my 6 year old.
Am I taking crazy pills or does a few mean three and a couple mean two?
72chevy2door
Florida
Jeff
1500 Sierra Classic suburban
@TJ I'm glad you got your 79 figured out. If I was you and this is my own opinion I would check the voltages you get off the alternator and ignition switch and various places to make sure your not also getting a voltage spike. I would also check all grounds and hots to make sure they all have good connections. Heat from manifold or header could caused the solenoid to go bad but I would still check. That's just my 2¢. But good idea to wrap the starter. Even if it wasent heat that killed it it will still help prevent it.
Thunder
Colorado
D.
Couple 2 Few 3 or more.
Summit, Eagle rotating assy. $599.97
Barnabyjo
