The Beginning of the End of my Wallet- 1990 prelude Si Build thread!
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
thanks, found it, how would i tell if it needs fixed/replaced?
You can usually listen for an audible click from the relay when you turn the key to the ignition on position (where it snaps back to after you start the car). You could also place your hand on it while someone turns the key and feel for the click, as well.
wheelerboy12
Dundee, OR
jeremy
She runs!!! She runs!!!! My baby runs!!!
Driver4r
Nebraska
Trevor
k10,c20
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Theres also tips that makes your exhaust whistle like it has a turbo(at least they try to make it sound like it)
Yeah I saw those, I need to get the dual exhaust conversion for my V6 Mustang before I try anything like that.
wheelerboy12
Dundee, OR
jeremy
Was it the relay?
yes it was, i pulled it out, melted and added solder to each pin put it back in turned my key... and then *click* *HUMMMMMMMMMMMM* and the fuel pump clicked on. :D im overly excited.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Sweet, glad I was able to save you a little hassle and time. Swapping fuel pumps is no fun!
wheelerboy12
Dundee, OR
jeremy
no fun, and expensive. considering i re-did my whole truck for 200 a 120 fuelpump was crazy!, and its not that bad on mine, i have an access panel i just pop it up unscrew three screws pull it up, unplug it pluf the new one int set it in screw it in and replace the access panel cover.
You fixed it already, but it the future you can tell by turning on the ignition and watching all the idiot lights come on, then after a second or two, you will hear a 'click' and a few of the lights will go out. If it doesn't do that, it's broke.
wheelerboy12
Dundee, OR
jeremy
was not relay... back to square one. ***** ******. how awesome....
woodsrider250
Fredneck, MD
350-Qjet
horse Power: 145 (want to get it dyno tested, i think it has way more then that)
It doesn't...they take to boost very well though.
wheelerboy12
Dundee, OR
jeremy
mine wont take to boost at all my car will blow up. from what ive seen through looking around the engine bay and the fact my rpo codes say my car came with the b20a1 and i have the b21a1 and the fact that im the only 3rd gen that dosnt burn oil im under the impression that the engine was rebuilt for high compression, i cant remember if i posted compression ratings here but im running almost 220 psi in every cylinder. normal for them right off the line is 175-180. and since its 20 years old, it should be more like 165-170. so yea.... pretty dope.
Obullard74
