TH400 Oil cooler Pan
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Do you have an aftermarket trans cooler mounted in front of the radiator? More efficient cooling for less money that way.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
This would be the way to go initially.
yevgenievich
Viktor
sad
very sad
less sad
I have both, cooler and the cooler pan on 4l80e. The pan helps a bit, but most of the bonus is it gave extra capacity of the fluid compared to factory pan
frankenstien
Fairbanks
mike
1500 Sierra Grande
383 CUI
I would bet those holes will get plugged with road grime over time and mud and muck.
I have a deep finned TCI on my th350, works well
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
Ok...
Brand?
Model?
How is that better than radiator cooler?
Jrgunn5150
Ionia Mi
J.R.
6.slow
Ok...
Brand?
Model?
I like Derale Brand cooler's. The use a stacked plate that works better than the common tube and fin design. B&M also has a few stacked plate type coolers.
Model, whatever the biggest one I can fit is.
Better than a radiator cooler? It has way more surface area to dissipate heat than two tubes running through hot ass antifreeze.
sw washington
darren
k2500
Pro's... cooler oil with drain plug
Con's..expensive
Needed? If you're pulling heavy loads... if not? Nope
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
That would work, but being a heat sink type without air flowing through it, it's not going to cool as well as the coolers that have air flowing through them.
@austinado16 went all-in with a Tru-Cool plate type and pusher fan. I'm sure that keeps temps in check.
@gpmorgan went with a finned type 6 pass cooler. Easy to imagine how much more time the fluid has to lose heat when it's making more passes.
I have an aftermarket four-pass cooler that's tied into my power steering system. I'm planning on moving that one lower and adding the six-pass model for the transmission. Reason I went with a finned cooler over the plate style is because I was thinking more air can flow through these which would avoid hot spots in the radiator. No proof of that, just my opinion, but the fact that you can see right through this compared to the plate cooler I have for engine oil makes me think the air flow to the radiator is not being blocked at all.
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
I'd heard/read that the stacked plate coolers transferred more heat, so that's why I went with the largest version sold by B&M/TruCool (same cooler, made by LONG, reboxed for either company) at about 11"x11"x1.5".
I also installed the cast aluminum, finned, deep (extra 3.5qt capacity) B&M trans pan, and put a mechanical temp gauge into it.
The last cooling mod was to installed the deeper 3 core copper radiator.
I'm still considering installing the much longer radiator and fan shroud that was used on the 2500 2WD pickups and Suburbans, but finding all the components from a truck being parted out, has become a challenge. But that radiator is huge, extending nearly to the driver's side headlight.
I did all this because I haul a 2,500lb tent trailer up in to the mountains during the summer months. The grades we pull are steep, winding, long, and 2 lane. So speeds are down in the 35mph range, and in near triple digit heat, that generates a ton heat in the engine and transmission.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I bought what sounds like the same cooler as Austinado, Long Tru-Cool LPD4590. 28,000 GVW cooler, biggest I could find. Long makes the stacked plate B&M coolers, so you can save some cash and just get the Tru-Cool and not pay B&M markup. I got mine on Amazon for $109, and it included an install kit. I'd definitely go that route before spending money on the cooler pan.
v2500burb
Jay
v2500
350ci
I like that one
Next questions:
Serviceable trans pan?
Thoughts?
Single best mod for the money??
Sorry for all the questions
yevgenievich
Viktor
sad
very sad
less sad
I always install a pan with a drain in it, but it is not necessary. Just depends on how long the vehicle will be kept. It is cheap to add a bung to existing pan as well.
Here are the pan and front tube/fin cooler on my 2500
v2500burb
Jay
v2500
350ci
Cooler on its way
I'll put on a serviceable pan next time I ha he trans fluid
87R10_Cruising
