Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
hello.
just trying to gather information on programming my sniper EFI. it can be programmed to control kickdown on my TH400. voltage is applied to the circuit just as oem switch would do, only you set it to be applied based on a chosen parameter.
my question is what do you guys think would be a good tps% to start with? what would most replicate factory throttle position percentage? my truck didn't come with a switch for me to look at/experiment with, so I would downshift at the column when necessary. I was going to start at 85%...is this too high, too low, am I even in the ballpark?
side question should I program the radiator fans to come on at the same temp as my thermostat is rated at? i.e. 185 degree thermostat, trigger fans at 185...
thanks!
thanks!
