TH350 issue
Gator
Iowa
Gator
In December/January, my truck started to not move when I shifted it into gear unless I gave it a lot of gas. The worst instance was one night, it wouldn't move but would go in reverse fine. I would give it about 1/2 to 3/4 throttle and it would barely move forward and then slowly work its way to working condition.
Then in January, after a good day of it running the best it ever had, I went to drive it in the morning and same problem but worst. I put it into drive and it idled just fine but wouldn't respond to throttle. It eventually idled down the road far enough and I decided to stop to try shifting the gears and seeing if it was just cold. When I shifted back to drive, it wouldn't move forward and hasn't since but reversed fine.
So now my problem is figuring out why it won't work in any drive gear. When it's in reverse, it will move perfect. I did notice after putting it in drive, that the driveshaft won't spin. The transmission makes no noises, movement or anything when it's put into drive.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Did you try L1 and L2 as well as 3rd gear? L1 and reverse share the same clutches.
Gator
Iowa
Gator
Yes. It'll move through drive gears without doing anything.
eatfood
