TH-350 vs. TH-350C filters:
fussfeld
east coast
j
c-10
4.3 v-6 262CID
Is the trans filter for a TH-350C different from a regular TH-350?
i thought the 350C has a notch cut out of it vs. a regular 350 which is square.
However, the AC Delco site lists the same filter as compatible with both transmissionses.
i don't want to drop the pan unless i'm sure i have the right filter. i have a 350C
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
It looks different to me. I checked the part numbers on RockAuto between a pre-lockup model and a later model. They had different numbers and specified whether for a C-model trans or not. I would just go on there and get the one for a C. I don't know a ton about the three speeds, but that's my two cents.
87R10_Cruising
