tbi parts
Swims350
Logan WV
none
I've got several tbi parts for sale, came from my 88 gmt400 with a 350.
rebuilt tb unit with ultimate tbi mods down, shaved down and smoothed, injector pod spaced up. It has a tps and IAC everything with it. I have another tps I'll throw in too, reason I have it was trying to diagnose a problem, and the new tps is on the tb now and made no change.
I'd like to ask $100 obo, not including the shipping cost.
stock tbi dist. bought new from autozone. Has cap and rotor, complete.
$75 obo
new coil, bought around same time as the above, $30? obo
I've got new chrome centerbolt valve covers, wing bolts, and fel pro blue reusable gaskets. I'd like to get $75 obo for the set, I paid $50 not counting shipping for the vc's and another $20 for the gaskets, then the wing bolts were like $10 a set or more.
I've also got an esc module, map sensor, and other misc. tbi stuff, so just ask.
Also stock gm alum. tbi intake. not sure what to ask for it. $50 obo I guess?
feel free to shoot me a price on anything. I'm only online once a week, usually and it's usually on wed. so just stick with me I'll get back to you on them.
Swims350
Logan WV
none
still got all this stuff.
Swims350
Logan WV
none
bump. again feel free to make offers on any of it
Swims350
Logan WV
none
still got it all, need rid of it, taking up space.
Swims350
Logan WV
none
also consider selling my serp. setup.. It uses a large steel horse shoe bracket and not alum ones. I would sell it with the PS pump or without, and just pulley included w/o the pump as I may need it to use with a v- belt setup.
I have the bracket setup, tensioner, 6 rib belt, water pump, and pulley, crank pulley, alt. in good working shape, and then ps pump and it's in good shape but I do need one I can use with v-belt or something if I sell it.
Swims350
Logan WV
none
nope it's not adjustable I seen no use in doing so. I just shaved the unit down and smooth the bores, then installed a pod spacer(thick gasket or 2).
Swims350
Logan WV
none
still got this stuff bumpity
83K5guy
Corpus
Justin
K5 Blazer
New injectors in tbi or old? What ended up being the problem with the truck?
Swims350
Logan WV
none
yep still have the tb and no not new injectors.
as for what happened and what was the problem no clue.
Swims350
Logan WV
none
completely tore apart, cleaned with carb cleaner, all new gaskets, made a pod spacer with the thick gaskets, cleaned the injectors with seafoam, a battery charger hooked to them and trigger then via a remote starter switch. Has new pressure reg. diaphram, and then the ridges around the injector holes/butterfly were shaved down smooth to the body of the tb and radius like inwards to make it smooth and polsihed. It's called the ultimate tbi mods. minus the adjustable reg. or putting in a stiffer spring or quarter to make more psi. I had also bought a new tps and installed it. iac was just cleaned and reset.
Swims350
Logan WV
none
so now no interest?
aaron06
