Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
Are these trucks pre-wired (like a signal wire under the hood) for the tach? I'm looking to temporarily add a 52mm (2") tach in the dash - got a spot for it just fine - but am wondering if there is a signal wire under the hood that wasn't hooked up to clusters without one.
I have seen some elude to it, so was wondering if its there to find. I'm used to hooking them up to a coil but the PO put an HEI distributor in....I'm not sure what brand even.
Sorry if this has been asked....most every post I find is about the factory tach add-on or something with the dash wiring / stock cluster.
Thanks.
Thanks.
