Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
ok square body gurus, once again I come to dip my cup into the well of knowledge! I would like to replace a tired 350C trans with a fresh 700 with lots of durability upgrades. My question, what’s needed to complete the swap? I have already replace the steering column with a later part, that will fix the shifter gate issue. The 350 trans has a long output shaft, anybody in readerland know if the driveshaft will fit? If not, I’m guessing driveshafts are pretty easy to find. I have a PRNDL indicator with the overdrive position, and have already addressed the lockup converter wiring, and modified the Q-Jet with throttle arms to accept the TV cable. I’m guessing the existing crosssmember can be reused? Anything I have overlooked? Thanks!!
