Swapping from auto to manual trans
RamblinGMC
Clovis Ca
Eddie
c2500
I am considering swapping my 1982 GMC with the 6.2 diesel from the Turbo 400 to a 4 Speed manual. What do I need to do this swap and is it doable? Thanks!
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Yes, it’s pretty simple. If you are going mechanical clutch linkage, I have a spare pedal assembly for that. If you are going hydraulic, the pedals are quite a bit more expensive and harder to come by.
They’re all factory parts you can source from Craigslist. I’d buy the flywheel, clutch, pressure plate, throwout bearing and pilot new.
RamblinGMC
Clovis Ca
Eddie
c2500
I have a bell housing and flywheel, assuming they are correct. I am fine with the mechanical clutch.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I have a pedal assembly if you don’t have luck sourcing the parts locally. I’m about a 3.5 hour drive from you though. I have a project in Amador county that I’ll be traveling to this week, but that’s about as far south as I’ll be headed for a while.
RamblinGMC
Clovis Ca
Eddie
c2500
Where are you located? Do you have just the pedals? Or do you have all the linkage too?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Just the pedals. I don’t post my exact location for privacy reasons. I’m in the Sierra Nevada foothills about 1 hour west of Lake Tahoe.
RamblinGMC
Clovis Ca
Eddie
c2500
Understood! I'm in the Sierra Nevada foothills as well. I'll let you know on the pedals as soon as I decide to go manual.
RamblinGMC
Clovis Ca
Eddie
c2500
When you get a chance, shoot me a PM of what you want for the pedals. I'm still weighing my options as to how to go about getting the truck back on the road. Thanks!
RamblinGMC
Clovis Ca
Eddie
c2500
Does the starter still bolt to the block when running a four speed? Or does it bolt to the bell housing?
idahovette
Weiser Idaho
Perry
K20-K10
Block, unless you use an older style cast iron bellhousing
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Will do
RamblinGMC
Clovis Ca
Eddie
c2500
Then I'm guessing finding a starter that would mesh with the 6.2 flywheel and have enough torque to spin the 6.2 would be a challenge.
Mousta5
