Suggestions: on plugs, wires, cap, rotor, and coil
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
Any thoughts on what the best replacement for the above are?
Wires on my truck are 24yrs old....
Help
v2500burb
Jay
v2500
350ci
I am looking at MSD wires, cap, rotor , and blaster coil
Not sure about plugs
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Use all stock AC-Delco parts. No need for aftermarket crap that will probably blow on you. Go down to the local parts store/rockauto/etc and grab all the OE parts you need, and make sure to use AC-Delco. Its not the "highest performance" parts, but they will be reliable and are almost guaranteed to work. You will be happy.
AC Delco
da_raabi
FloriDUH
Adam
c30
^^His signature lol. Aftermarket high performance stuff is only needed if everything else is aftermarket too. I tried putting an accel super coil on my old Dodge and all it did was kill my gas mileage and eventually blow up. Same vehicle, I tried fancy platinum plugs and ugh, that thing ran like crap. Popped the $1 OE champion coppers back in and wow, it was like a new truck. Lesson: Stock is used by the OE for a reason. Engineers that get paid a HELL of a lot more than you or I do years of research and design to get these things right, so lets trust them!
350runner
tx
Ceasar
Msd cap and rotor acdelco everything else.
rich weyand
Bloomington Indiana
Rich
Cap and rotor: Accel 8122
Coil: Accel 140013
Plugs: Autolite 26
Wires: Taylor 74206
I've had great luck with Accel products, just NOT their caps or rotors. But in most cases, ACDelco for everything! You can substitute plugs/wires with Accel if you want, they last every bit as long as ACDelco stuff. And NAPA blue plug wires are really good too.
v2500burb
Jay
v2500
350ci
Thank you
I have gotten all ac delco parts and Autolite plugs
What about electric fan(s)??
What are your thoughts??
With temperature control and manual control...
v2500burb
Jay
v2500
350ci
Also....
A good water pump???
High flow?
Mine is 24yrs old and this truck sat for years
I want to slowly work on replacing everything!!!
It has all new hoses.... New radiator
Um, why Autolite plugs?
Stock replacement water pumps do just fine. There's several electric fan threads around here too.
v2500burb
Jay
v2500
350ci
I already them....
Even with the rear heat a stock water pump??
Yeah the stock pumps flow well.
350runner
tx
Ceasar
GM designed things well back in the day. It's not flow one should be concerned about... only heat transfer. That's what really matters
blazerguy33
