suburban middle seat belt floor bolts
annettemarie
Cookeville, Tennessee
Annette
Chevrolet Suburban V10 Silverado
I beg you all tell me what grade this dang bolt is? Im going nutso with these bolts. I want to replace them with hex head since the stupid torx bolts suck. I know its metric ( M12) and the thread size is 1.75 but the grade is where im stuck.
annettemarie
Annette
FYI the RED arrow is pointing to what I believe is a nick from the torx bit. Not the machined markings
Turbo4whl
Downingtown, PA
Wayne
Seat belt bolts are very special. They are made to lock in place like a stover nut does. (distorted thread) If you look close you will see the bolt is not perfectly round, but more like a triangle, this distortion locks the thread.
Grade wise, at least 10.9 or 12.9
For future reference, if you heat them from the underside, they come out real easy.
annettemarie
Annette
Thank you so much that is a big help. I did heat them and it still took 2 days of PB blaster and then Free All, three Torx bits and a torch. They were really rusted in there. I wanted to be certain I use the right grade for my daughters safety. Thanks for being so quick and for the picture Turbo4wheel
annettemarie
Annette
Do you guys think one of these bolts is a better choice than the other? I wonder if the phos & oil bolt will prevent it from locking down as tight even with a thread locker. Thoughts?
Normally I'd say the yellow zinc bolts may tend to rust faster, but these days, the quality of the coatings seems to be hit/miss.
87ScottW
