Stock oil filter adapter
robert8096
Goose Creek SC
Robert
On a small block 350 does the oil filter adapter require a gasket?
Sent from my SM-J700T using Tapatalk
BigUgly469
350 CI
Looks to be the piece that the oil filter itself screws on to. If that is what that piece is than no it doesn't. The O-ring on the oil filter provides the seal.
Sent from my SAMSUNG-SM-G930A using Tapatalk
74 Shortbed
The adapters never came with a gasket from the factory.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
I just put a new one of those on my new to me 454. It came out of an RV so it had a funky remote oil filter setup. I did not use a gasket. No leaks as of yet. As stated before, the filter o-ring provides the seal to the outside world. The only thing a gasket on that adapter would do is ensure absolutely no oil bypasses the filter. It would be such a small amount its not really a big deal. It should be fine without.
74 Shortbed
The adapter don't leak against the block and a gasket is worthless it does not ensure all oil goes through the filter, the BIG leak is the funky bypass in the adapter which GM put there for cold starts and people that won't change oil, on cold starts especially with a heavy weight oil half of it is bypassed and don't go through the filter until the oil warms up and thins out, put a pipe plug in and all oil will go through the filter, you really notice it too from the high oil pressure when cold.
robert8096
Goose Creek SC
Robert
Thanks guys. Did more research and came to the conclusion there was no gasket needed unless you were using the one for a remote oil cooler or filter.
74 Shortbed
All the remote units I've ever used had o-rings and no gaskets.
johnalen76
