Steering shaft removal
SquareRoot
Can the steering shaft be removed without unbolting the steering column or steering box? I just swapped my column and buttoned it up and wouldn't you know I score an xj shaft the next day.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yeah, it’s collapsible. You may have to help it a little bit, but it shouldn’t put up much of a fight.
SquareRoot
Cool. Was hoping I didn't have to melt any plastic inserts out like the xj one.
yevgenievich
Viktor
sad
very sad
less sad
It is usually freely collapsible
Craig 85
Nashville, TN
454/TH-400/NP205
I just did the swap on mine yesterday. The rag joint was so bad removal was easy.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Which year XJs work? I can’t recall...
SquareRoot
Got it swapped last night. Great low buck mod.
85-95 xj.
Camar068
10 yrs Air Force
SquareRoot
I only use oil based enamel. Bead blast and wipe clean with acetone. Takes a good 24 he to cure but it will last forever. If it comes out of a rattle can it won't last. I paint all my non factory parts red.
bigcreek
