steering column repaired, NOW more problems
80goldenburb
LV,LV Raider Nation capital
Nico
Suburban C20
'68 cad 472
I took apart my column to tighten those infamous torque screws that come loose. Glad i did but turns out that was only half the problem. More tightening needed at lower column area, at a later time. After putting it all back together, I have no power whatsoever when the key is turned to ACC. The ignition cylinder also has no recoil/tension in the crank position. The shift lever also stays locked. What did i do wrong?
The mechanism from sector to neutral position is exactly how i have mine.
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
If I remember right it will be related to that "ignition switch actuator rack." Something in there was a @&$*^. Sorry I can't remember the details. That spring I think.
Sent from my iPad using Tapatalk
80goldenburb
Nico
Suburban C20
'68 cad 472
All is good now, the "wedge" metal piece in front of the actuator rod was not aligned correctly at first.
highdesertrange
kalifornia
mike
k30
ah the old misaligned wedgie. highdesertranger
88SQDRW
