Square body suggestion needed
squarebodytrucker
Cutknife saskatchewan
Orville
Gm
Good evening folks I'm rewiring my inside harness an I need your input 1st off is that a relay box on top of the fuse box panel? Also need someone to send me a picture of a completely wired an fused panel for 84 to 87 square body, an I totally appreciate any positive input an thoughts regarding my post an thank you
squarebodytrucker
Orville
Gm
Good evening folks just got my 1st trophy someone's seen me doing my dishes ..lol..decided to come in getting a bit on the chilly side up here in Canada..hagn
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. We love pics here.
Try searching the Electrical & Audio forum. There are tons of information here.
Get a wiring diagram for your truck, you don't know if somebody already fiddled with the wires.
https://www.gmsquarebody.com/forums/electrical-audio.7/
squarebodytrucker
Orville
Gm
Gm Ali I'm not at all sure if someone else has worked on this truck however realistically I'm sure that someone else put they're paws to work or break..lol..see I don't quite understand the lines of the wiring diagrams it be beneficial for me to see the actual wiring..
squarebodytrucker
Orville
Gm
I'm getting mixed reviews from other sources some are saying that an 84 carb an 87 tbi wiring harnesses won't work ??
An what's best the way to bypass the dual fuel tank switch an just use the one tank? Can I just tape up the wiring from the right tank and use the left tank ??
:welcome:
Tommyutah
